Hello,
I am trying to set names in the hotcues in this version but I am unable, I tried using the different defaults skins to see if it were possible with this but there was no way.
Is there any skin/way to set names on cues?
Thank you.
Thank you.
geposted Thu 10 Oct 19 @ 2:26 pm
You will need to open the POI Editor. http://www.virtualdj.com/manuals/virtualdj/editors/poieditor.html
You can do that if you right-click on the loaded Track's Cover, or from the Hotcues Pads page menu, or if you have the tracj in Browser with the right-click menu.
geposted Thu 10 Oct 19 @ 2:30 pm
From either the cue menu or pad menu, set 'display mode' to 'name'. Then if you're using pads, select 'Edit CUEs and POIs', or from the hotcue panel, right click the cue boxes.
geposted Thu 10 Oct 19 @ 2:42 pm
