Topic: VDJ 2020 hotcues with names?
Hello,
I am trying to set names in the hotcues in this version but I am unable, I tried using the different defaults skins to see if it were possible with this but there was no way.
Is there any skin/way to set names on cues?
Thank you.
geposted Thu 10 Oct 19 @ 2:26 pm
geposted Thu 10 Oct 19 @ 2:30 pm
From either the cue menu or pad menu, set 'display mode' to 'name'. Then if you're using pads, select 'Edit CUEs and POIs', or from the hotcue panel, right click the cue boxes.
geposted Thu 10 Oct 19 @ 2:42 pm
