The icons on the left of the Pro skin (and I believe the other new, included VDJ skins) indicating music, video, karaoke do not change color when pressed. It's tough to tell what's being displayed. I believe previous versions changed color. Is there a way to edit the skin to tell those icons to change color when pressed, or can VDJ correct this? Thanks
geposted Thu 10 Oct 19 @ 7:13 pm
This has been noted by devs, and has been said it will be looked at.
geposted Thu 10 Oct 19 @ 7:29 pm
Thank you.
geposted Thu 10 Oct 19 @ 7:34 pm
You can do this with a little bit of editing...
Simply change the colour definition for "browser_iconbuttondown".
geposted Thu 10 Oct 19 @ 8:00 pm
OK, I see that line in 3 different places in the xml file. Can you walk me through what exactly I should do? I'm not afraid to edit the xml, I just don't know what to put in there to make it do what I want. Thanks.
geposted Thu 10 Oct 19 @ 8:30 pm
Check out this thread. I wanted to make mine more apparent as well.
https://virtualdj.com/forums/231032/VirtualDJ_Skins/_Show_Only__buttons_in_2020.html
geposted Thu 10 Oct 19 @ 9:05 pm
Under group name="colorscheme" near the start of the XML, there's a section marked <!-- browser icon buttons -->
The the one that says define color="browser_iconbuttondown" is the one to change. The green I used is #008000
