VDJ not picking up newly added sub folder on external hardrive that I have always used for my music storage. I can see the folder on the hard drive and all music is playing fine but when I open VDJ the new sub folders dont exist. If I move the music to a general folder then it is there.
geposted Sun 13 Oct 19 @ 7:10 pm
Nobody?
geposted Tue 15 Oct 19 @ 2:10 am
Did you add it to the search database within vdj?
geposted Tue 15 Oct 19 @ 8:10 am
Hi, yes I have several times. Makes no difference and when in VDJ the folders don't exist when I look for them in the hard drive section. However if looking through the hard drives outside VDJ they are there and play through other software. This has only happened after upgrading in the past two weeks.
geposted Tue 15 Oct 19 @ 1:48 pm
I have found them. They have added themselves to the bottom of all of my sub folders - so now out of alphabetical order - Like a whole new range of folders...
geposted Tue 15 Oct 19 @ 2:00 pm
You can right-click on the parent folder and select 'reset order' if you want them all to be in alphabetical order instead.
geposted Tue 15 Oct 19 @ 2:05 pm
Thanks
geposted Tue 15 Oct 19 @ 11:02 pm
