Some kind of Traktor's STEMS feature, but in a different way:
Let's say I have a song that has Main/instrumental/acapella, i want to be able to group all versions together and play with that, for more advanced mixing techniques.
That could be achieved with some kind of a song editor and just have them all rendered into one track (that's what i do now, using an external DAW)
but that's the messy way.
Maybe just have the ability to not limit your 8 cues to the same track...
There might be a problem with fast loading times because it means skipping between 3 tracks (or more) but maybe if you group the songs together, the software will know to preload them together for a smooth transition between cues.
geposted Wed 16 Oct 19 @ 1:53 am
You could load both versions in a different deck, and perhaps create a pad page that stops the other deck and jumps to the wanted cue point
geposted Wed 16 Oct 19 @ 2:03 am
You can have as many hotcues as you like. [hundreds if you wish]
I've an idea I've been sitting on for remix decks but I think it would work in a stems kind of way too.
geposted Wed 16 Oct 19 @ 2:24 am
