Hi Guys.. Need your assistant.
Using skin with 2 decks, where A = Automix (Songs Playback) and B = Karaoke.
I've created button for the automated Deck B Karaoke playback using Effect "StereoChannel" which suppose to select Left, Right or "Doing Nothing" base on my filename or Remix tab in the "ID Tag" section.
I've added in the Remix ID Tag or End Of my filename, (in bracket)
-LM1 meaning Left Track for Minus one,
-RM1 = Left Track Minus One or
-FM1 = Track with Stereo Minus One
exp my filename:
James Hullon - Far From Home (LM1).mp4
Deck B Custom Button currently contains:
deck 2 play & auto_crossfade 100% & deck 1 stop & get_remix_after_title "LM1" ? & deck master effect_active "StereoChannel" & effect_button 1 : nothing : & get_remix_after_title "RM1" ? & deck master effect_active "StereoChannel" & effect_button 2 : nothing
Question is, I've no idea hot to get this script to read the LM1/RM1 (not very familiar with the script) from the Remix ID Tagging or in bracket at the end of filename in order to activate the Effect Stereo Channel and afterward select either Left or Right Channel.
Can Somebody assist me. Thanking you guys in Advance.
exp my filename:
geposted Wed 16 Oct 19 @ 7:24 am
param_equal "`get_loaded_song 'remix'`" "YOURSTRING" ? TRUE : FALSE
geposted Wed 16 Oct 19 @ 7:35 am
Thanks .. very fast respond - but is this right?
deck 2 play & auto_crossfade 100% & deck 1 stop & param_equal "`get_loaded_song 'remix'`" "LM1" ? & deck master effect_active "StereoChannel" & effect_button 1 : nothing : & param_equal "`get_loaded_song 'remix'`" "RM1" ? & deck master effect_active "StereoChannel" & effect_button 2 : nothing
or
deck 2 play & auto_crossfade 100% & deck 1 stop & param_equal "`get_loaded_song 'LM1'`" ? & deck master effect_active "StereoChannel" & effect_button 1 : nothing : & param_equal "`get_loaded_song 'RM1'`" ? & deck master effect_active "StereoChannel" & effect_button 2 : nothing
Still not working .
or
Still not working .
geposted Wed 16 Oct 19 @ 7:41 am
top one looks there abouts, but you say this for deck 2, when you "deck 1 stop" you shift the scripts focus to deck 1, start the param_equal bit with deck 2 to make deck 2 the focus *edit, too many nothings too*
deck 2 play & auto_crossfade 100% & deck 1 stop & deck 2 param_equal "`get_loaded_song 'remix'`" "LM1" ? deck master effect_active "StereoChannel" & effect_button 1 : param_equal "`get_loaded_song 'remix'`" "RM1" ? deck master effect_active "StereoChannel" & effect_button 2 : nothing
geposted Wed 16 Oct 19 @ 7:54 am
Yes... It's Work - Many Thanks - Solved My Headache :-)
geposted Wed 16 Oct 19 @ 7:57 am
