Hello
I am trying to figure out what I think should be a simple solution. I would like to utilize the event scheduler to turn my logo on and off at a set interval.
as in:
Logo is displayed for 30 seconds every 5 minutes
I don't think this should be too difficult. I assume it would be in a script. Is the " videoLogo " attribute accessible through the script
Thank you in advance!!!
as in:
geposted Wed 16 Oct 19 @ 8:27 pm
setting 'videoLogo' 0 & repeat_start_instant 'rsi5mins' 300000ms & repeat_start_instant 'rsi30sec' 30000ms 2 & setting 'videoLogo'
geposted Wed 16 Oct 19 @ 8:37 pm
Locodog!!!! You are awesome
Thank you so much!!
Seems to be working perfectly! I may tweak the times slightly but it works flawlessly!!!
It was a little more complicated than I was thinking but looking at it it does seem to make sense.
Thanks again!!!
Thank you so much!!
Thanks again!!!
geposted Thu 17 Oct 19 @ 4:26 am
geposted Thu 17 Oct 19 @ 7:09 pm
