Topic: VDJ 2020 Jumping in middle of tracks
RayCovPRO InfinityMember since 2014
Hi, VDJ has started jumping at random points in songs and skipping big sections of songs.
This only seems to be on automix when I'm also running a karaoke.
Had a look online and help seems to point to the BMP match? Anyone else had this issue and know if this is the problem?
Many thanks
geposted Thu 17 Oct 19 @ 9:08 pm
What Hardware?, 99% of the time random jumping is needle search reacting to vibration
geposted Thu 17 Oct 19 @ 9:54 pm
Hi, I don't use any external controller, just my laptop which is a MSI Ge63 Raider, i7, 16gb Ram.. I had a look at the settings yesterday follow g some searching and it seems to be something with the auto BPM match and pitch. After disabling the auto BPM and pitch reset on load turned on, it seems to run fine.
I know my machine updated the sound drivers recently so that too may be an issue, will monitor and update if the adjustments fix it.
Cheers
geposted Fri 18 Oct 19 @ 7:36 am
I must agree with this. I've had this happen multiple times during the last 2 weeks
geposted Sat 19 Oct 19 @ 4:21 am
