I Installed the 64-bit version to try and find me that the videos will not be seen, only the audio will be skipped over the trays where it would tend to see the video solo falling in black. If you can not get an error in the configuration, simply my pc is not compatible. In 32-bit version works normal.
geposted Fri 18 Oct 19 @ 1:04 am
without more info ... yes maybe your PC is not compatible
it sound like a graphic board not fully directx 11 complient
core duo, i3 i5 1st & 2nd generation pre intel HD 2000, old geforce ...
try whenever shader and CDG and covers are working ...
my core2 duo E6700 with intel G45 is an example
geposted Fri 18 Oct 19 @ 1:18 am
I messed your previous post;
yes, the Intel Core I5 M450 video board is reported as not compatible - dx10.0 only
"It has also been proven by uninstalling the driver and running VDJ x64 with the basic windows 10 drivers and it works fine. When I install the official drivers, VDJ stops working again."
Thanks for the info!! good news. The I5 CPU is fast enough to handle the software decoding by itself, and MS did the workaround
however instead oF being more powerfull the 64Bit VDJ may only take more CPU ... with better FPS
you may have saved my I5 M520 though
geposted Fri 18 Oct 19 @ 1:40 am
