where if anywhere can I find a full list of the midi mapping designations for the Akai Apc 40 mk2 as I can only find a brief limited amount contained within the documents held attached to the supported hardware
geposted Fri 18 Oct 19 @ 8:39 pm
Er...what does that mean?
Assuming you want to use the controller with VDJ, the setup guide is here https://www.virtualdj.com/manuals/hardware/akai/apc40mkii/index.html
geposted Fri 18 Oct 19 @ 10:09 pm
