Topic: Denon MCX8000 cue pads dont light up.
TUNES69PRO InfinityMember since 2007
Using VDJ8, Win7 with Denon MCX8000 for a couple of years. Today the pads don't light where my cue points are.
Any ideas.
geposted Sun 20 Oct 19 @ 5:45 pm
So your MCX8000 pads still trigger Hotcues, but their Leds are off ?
Same if you switch to a different Pads page/mode and back to Hotcues ?
Do you happen to have a hotcues.xml in /Documents/VirtualDJ/Pads ? If so, delete the file and try again.
geposted Mon 21 Oct 19 @ 11:47 am
