You can expand the search box from the bottom corner to make it wider.
Would be good to have adjustable columns and remember the box size if changed.
geposted Sun 14 Jun 20 @ 4:03 pm
Hello,
i have tested the function extensively and it works better than i hoped.
But I still have one more thing.
Is it possible to insert a button, search only in playlist?
Thanks again for the good work.
geposted Sun 27 Sep 20 @ 8:53 am
yes put this on a custom button
search_playlists
search_playlists
geposted Sun 27 Sep 20 @ 12:28 pm
search_playlists
search_playlists
But then he also looks in history and virtual folders
geposted Sun 27 Sep 20 @ 6:50 pm
