Team, i am having troubles with Sound Driver, see, some times while i am playing and mixing my music, that is Works normally, and then suddenly the sound begins to hear so dirthy and fast, the sound of the music is totally out of rithym and sound, the the only that i found to fix this error, is in THE SEETINGS, then SOUND option, is to pushig the APPLY button again without make any changes in this setting, then sound recover the properties and Works perfectly it fails so ofthen that ia have to decide not to record my mixes, cause this crasses are ruined my recordings.
what do i have to do? in the mean time, i am wating the update of VDJ , to see if this error is corrected
geposted Tue 22 Oct 19 @ 8:48 pm
if windows have a scan of your system with
https://www.resplendence.com/latencymon
there very well could be a vdj bug but first [and easiest] test is your system
also ensure you are using the most recent public build
geposted Tue 22 Oct 19 @ 9:26 pm
It would help if you told us what "sound driver" you're referring to....
Mac or PC? Are you using your built in audio, or an external interface, or a controller with onboard sound?
If PC, are you using ASIO, WASAPI, something else? What's your audio buffer size set to?
geposted Wed 23 Oct 19 @ 4:34 pm
