Topic: Mix Assist in other skins
I love the new mix assist in Virtual DJ ‘s 2020 starter skin. Is there a way to put it the other skins? How can I set a button on my controller to activate mix assist? I don’t see it in the controller options. Thank you
geposted Wed 23 Oct 19 @ 12:30 am
You can use "effect_mixfx" action to select a mix effect and then use "effect_mix_activate" to toggle mix effect on/off
geposted Wed 23 Oct 19 @ 9:31 am
Can you clarify please. Not sure what you mean.
I see the effect_mixfx in the options but I am not sure how the script should read. Any help would be greatly appreciated thanks!
geposted Thu 24 Oct 19 @ 11:42 am
He’s told you what you need to enter on your custom button. There’s nothing else to it.
geposted Thu 24 Oct 19 @ 11:55 am
What is this effect. Can't see anything about it in the changelog?
geposted Thu 24 Oct 19 @ 12:15 pm
geposted Thu 24 Oct 19 @ 12:37 pm
Could easily add to custom button.
geposted Thu 24 Oct 19 @ 12:45 pm
