Hi everyone,
Switched from Serato to Virtual DJ. I have an MC7000 mixer and I would like the hotcue pads to operate the same way as Serato.
So when the song is paused, I want the music to play only while I am pressing down on the pad, and once released, return to cue point.
When song is playing, and I hit hot cue, I want song to continue playing from that point on.
I also want my hot cues to be locked in, unless I choose to delete them. I don't want the location of the hot cue to change whenever I hit the pads.
Thanks guys
Thanks guys
geposted Wed 23 Oct 19 @ 6:20 pm
http://www.virtualdj.com/wiki/seratosettings.html
only shift+pad will delete a hotcue, if you really want you could individually lock hotcues in a per track basis with the pad menu read only option
geposted Wed 23 Oct 19 @ 6:33 pm
Set Hotcue mode to stutter in settings..
geposted Wed 23 Oct 19 @ 6:34 pm
Thanks for your help guys, now it works the way I wanted it to.
Cheers
Cheers
geposted Sat 26 Oct 19 @ 1:53 pm
