Forum: VirtualDJ Skins
Topic: radius can't compute and or use computed placeholders
NicotuxHome userMember since 2014
creating a custom jog
<visual type="circle" source="get position" x="+2" y="+2" width="200-4" height="200-4">
<on shape="circle" color="deckcolor" radius="84" border_size="2" border="bordercolor"/>
</visual>
works perfectly
<on shape="circle" color="deckcolor" radius="42*2" border_size="2" border="bordercolor"/>
would work but radius is set to 42
now the same when used with placeholders="*size=200" in a way to create different size using only one definition
<visual type="circle" source="get position" x="+2" y="+2" width="[SIZE]-4" height="[SIZE]-4">
<on shape="circle" color="deckcolor" radius="[SIZE]*42%" border_size="2" border="bordercolor"/>
<on shape="circle" color="deckcolor" radius="[SIZE]*0.42" border_size="2" border="bordercolor"/>
won't work because math with are integer only
<on shape="circle" color="deckcolor" radius="[SIZE]*42/100" border_size="2" border="bordercolor"/>
would work but this kills the elements and nothing display - not radius set to 0 or 42
<on shape="circle" color="deckcolor" radius="42*[SIZE]/100" border_size="2" border="bordercolor"/>
adding a placeholder
<define class="jogwheel" placeholders="*size=200,*radius=84">
<on shape="circle" color="deckcolor" radius="[RADIUS]" border_size="2" border="bordercolor"/>
will work as long as radius is a constant
geposted Mon 28 Oct 19 @ 3:52 am
No news?
Already no way to compute radius either from placeholders or hardcoded
when multiple placeholders can be used ^^
radius="[R1][R2]"
as well as other strange things
radius="[R1]0" equivalent to pseudo (R1*10)
radius="1[R2]" equivalent to 10+R2
geposted Sat 20 Feb 21 @ 8:47 pm
Will be fixed in next update. +-/* was only available for integer fields, and radius was read as floating point field, but I guess that was not really necessary.
geposted Sun 21 Feb 21 @ 7:43 am
useful to draw discs where radius is center hole and rectangles with proportional round angles
also needed to be able to draw "eyes" shapes where radius depends both width or height
Thanks
geposted Sun 21 Feb 21 @ 10:27 am
