Hi everyone
i take last year one ddj wego pioneer controller with we-go cd together and to upload my computer and enter controller code and work but i change my computer now and i cant use my controller because the program always say me this code registered another computer and my cd is broken i cant upload cd again so i cant use controller virtual dj program
i have controller i have computer but i cant use suggest me a solution for this...
many thanks
many thanks
geposted Tue 29 Oct 19 @ 8:13 pm
If you did not make a note of the serial number, you did not register the serial number here, and you allowed your CD to become damaged, there is no solution.
geposted Tue 29 Oct 19 @ 8:20 pm
MONONOKEE wrote :
Hi everyone
Licenses and codes are registered to the account.
And since you do not have that on the current account, perhaps you used a different user account before?
If so, simply add the email from your other account here:
http://www.virtualdj.com/users/link.html
After that the LE code will work with the current login
geposted Tue 29 Oct 19 @ 8:35 pm
