I have a show coming up where they want all the videos mixed at precise times etc. I started using the video editor to sort them all out etc and after doing a few i though i would see what it looked like . they look pefect when you play them on the editor but when you hiut auto mix they dont mix at the correct points ,
Any sugestions guys? Ive tried the save, close and re open , tried other videos , just cant work out why they are pefect on the editor screen and then not in automix
geposted Tue 29 Oct 19 @ 8:35 pm
Automix uses different POI (Points of interest) for each type of automix (fade, cut, etc.). There is also an Automix Editor that you can use to create a "playlist" of that mix.
Using the automix
User Manual - POI Editor
User Manual - automix Editor
Using the automix
geposted Wed 06 Nov 19 @ 2:18 am
