Topic: virtual dj 2020 crossfader
How do I increase the response speed on a central crossfider? How do I reduce controller crossfeider latency?
geposted Sun 03 Nov 19 @ 11:09 am
There shouldn't be any latency.
If you have a delay then it is likely to be caused by your hardware (are you using a controller? which one?) or your audio setup (again, what are you using?).
geposted Sun 03 Nov 19 @ 11:11 am
There is a reloop beatmix 4. In tractor, everything works well, in virtual dj observed delay
geposted Sun 03 Nov 19 @ 11:19 am
