Topic: popping noise
In Virtual DJ8 I keep getting popping noise through speakers and headphones and occasionally the music will freeze for about 1to 2 seconds.
geposted Sun 03 Nov 19 @ 9:23 pm
Which controller? Do you have the latest drivers and firmware? PC or Mac? Post a pic of you audio settings.
geposted Sun 03 Nov 19 @ 9:26 pm
What controller are you using and which sound drivers .... WASAPI or ASIO?
Sounds like a latency issue.
geposted Sun 03 Nov 19 @ 9:27 pm
Numark Mix track 2 and using the ASIO driver
geposted Sun 03 Nov 19 @ 9:31 pm
So, do you have the latest drivers and firmware? Did this just start, or has it been like this with this controller? Any changes to your computer or VirtualDJ, as in Windows updates, or VDJ updates?
geposted Sun 03 Nov 19 @ 9:38 pm
What's your ASIO latency set to at the moment? You know you're supposed to adjust it to suit your system (so it doesn't glitch).....right?
geposted Sun 03 Nov 19 @ 9:48 pm
