Topic: Virtual folder not showing
Good day seniors.
Please some of my virtual folder showing and other too not showing on the Virtual dj but it's on the hard drive and that place too it shows.
Please I need help for that thanks.
geposted Wed 06 Nov 19 @ 9:23 am
By any chance are the tracks that are in that folder on an external drive that is not connected?
Did you possibly drag the virtual folder into another one?
No please.
In the file explorer I can see the Virtual folder but not showing on the VDJ and others too show
The "Virtual Folder" is just a database file in your VDJ system folder, usually in My Documents on a windows PC. It is not an actual folder on a drive. For example: C:\Users\username\Documents\VIrtualDJ\Folders. In the "Folders" directory there would be mini databases like playlists that hold the track file paths.
That is why I asked about an external drive. If you create a virtual folder, and the songs are on an external, and you remove the drive, the folder disappears until you add the drive back.
What is the file path for your Virtual folder?
