Topic: files not found
I have a license Home Plus (JBSystems DJ-KONTROL3) en downloades VirtualDJ 2020. It can not play the files.
Error: bestand niet gevonden (= file not found).
What's wrong?
geposted Sat 09 Nov 19 @ 5:32 pm
tjenhill wrote :
file not found. What's wrong?
If VDJ cannot find your files, either you have moved them, deleted them or renamed them outside of VDJ - and so they are no longer in the location (or have the same name) as the information in the VDJ database.
Are they on an internal or external drive?
There are two steps to solving the problem. 1) Clean the database (remove missing files) 2) Rescan the folder where the files are located, to add them back to the database.
Internal drive. Same location as on my old laptop, there it works good.
