Topic: Smart Key Match option in the Sync menu
Where is the menu and how do I turn this off?
geposted Mon 11 Nov 19 @ 6:53 pm
LIMOLPRO InfinityMember since 2003
Go to config / options / Autokey and check No
geposted Mon 11 Nov 19 @ 7:04 pm
Thank you! I would have never found it, why does it tell you "Sync" menu or "Smarty Key Match" if that's not whats on the actual menu. Seems counter productive.
geposted Mon 11 Nov 19 @ 7:44 pm
Because you can turn it off on the SYNC menu (Click on the word "SYNC" on default VirtualDJ 2020 skin)
The method provided above does the same job from within VirtualDJ settings.
The SYNC menu does exactly the same, but without needing to go into settings
geposted Mon 11 Nov 19 @ 7:48 pm
JoshTorresDJ wrote :
why does it tell you "Sync" menu...
Because its in the sync menu :)
You also find it in deck options (in all layouts)
geposted Mon 11 Nov 19 @ 7:51 pm
In the PRO skin of Virtual DJ 2021 there is no menu (I click Sync and no menu appears) I found the message very confusing.
geposted Sat 28 Nov 20 @ 6:05 pm
geposted Sat 28 Nov 20 @ 6:28 pm
