Topic: Changing the direction of my volume control
Greetings. I had this working before my catastrophic Issues with the upgrade to 2020. Now I'm working to restore the custom settings on my DJ2GO.
I changed the pitch control to a level control. But the direction of level from 0 to 100 is opposite what I want.
When I move the slider UP the volume level goes DOWN. I can't remember what script I had. And I've had no luck searching.
What modifier do I need to reverse the direction of the slider. PITCH LEVEL ?????
geposted Tue 12 Nov 19 @ 2:02 pm
I'm sure you put invert before the command
almost,
param_invert & pitch
Thanks LocoDog.
param_invert & pitch Works beautifully.
You Gurus amaze me. :)
That's it. To be fair I haven't looked at my mapper in a while :)
I had to check, I wasn't sure if just 'invert' worked with the v7 syntax.
