Guys I’ve been blessed with some time off, which I’ve spent making some major changes. Not major issues but I’ve noticed a few distinct changes in VDJ’s most resent build.
1. I’m finding the auto gain not very consistent, I was running flat out tonight and the audible difference between tracks was very noticeable. Running with Auto and remember but auto alone had noticeable difference.
2. The sync of tracks has a terribly glitchy sound whilst syncing. Obviously ok when syncing before mix but there’s no chance I’d hit sync (sync_play) whilst on FOH.
3. There were certain tracks which I’ve played many times previously but tonight played with a slight skipping judder.
Windows 10
Audio interface - XR18 “AISO” driver
Sample rate - 48k at 24bit
Controller - X-Touch one
Anyone else experiencing similar problems?
Ive recently changed my controller but everything else is the same.
Windows 10
geposted Sun 17 Nov 19 @ 1:12 am
Sample rate - 48k
Why? do you do mostly video?
geposted Sun 17 Nov 19 @ 5:44 am
It’s the native sample rate of the xr18, you can dull it down to 44 but it really doesn’t play well with others.
geposted Sun 17 Nov 19 @ 11:05 am
Hi All.
My first comment.
I noticed this Judder/stutter/latency issue recently. It happens mid song. I thought it was an electrical issue with loose charger/controller power connection ........until it happend again .
There is definitely any issue........ I welcome any solution as it can be quite embarasing when playng at a party
Window 10 64bit
CPU 2.50
VDJ 2020
My first comment.
Window 10 64bit
CPU 2.50
VDJ 2020
geposted Sat 07 Dec 19 @ 11:51 pm
mine gets so bad till my skin locks up or the music glitches real bad I want my last 2018 version back at least with that 1 everything ran fine with no problems (PS) my laptop is aDell latitude i7 with 12 gigs of ram
geposted Sun 08 Dec 19 @ 12:15 am
Same issues here.
Gain doesnt do a thing ... and the syncing/beatlock are really horrible in many cases.
Anyone please have a solution ... dont really want to find another mixing program.
But with these kinda problems its not fun to do a live session.
HELP! :(
HELP! :(
geposted Tue 09 Jun 20 @ 10:03 pm
