I'm having problems using the soundcard function of this mixer. After tinkering around with the settings, I finally got it to hear the timecode, but it doesn't seem to understand the signal. I'm using the latest timecode downloaded from the website. I have other soundcards that work so I don't know if my setting are incorrect or if the mixer itself are to blame. I'm not a newbie so I thought I cod figure it out. I was mistaken.
Could use some help on this situation before I send it back.
geposted Mon 18 Nov 19 @ 9:12 pm
https://www.virtualdj.com/contact/answers.html?id=109
Best I can do On this. Hope it Helps.
geposted Tue 19 Nov 19 @ 12:46 am
Did you follow the setup guide?
https://www.virtualdj.com/manuals/hardware/gemini/pmx10/advanced.html
geposted Tue 19 Nov 19 @ 5:31 pm
