With the new program version I have this problem. When a song is playing on deck 1 and load another song on deck 2 the active track changes automatically and music stops before I start playing the song on deck 2.... ??!!
What can I do?
Jukka'
Finland
What can I do?
Jukka'
Finland
geposted Fri 22 Nov 19 @ 4:27 pm
Does the Deck appear as playing on screen ?
If it's only audio that stops, then probably you send Headphones signal (PFL) to the same channel as the Master Output ?
Are you using any specific controller/hardware/sound card?
What is your Audio setup in VirtualDJ ?
geposted Fri 22 Nov 19 @ 4:31 pm
Yes thank you I did factory reset and now it works ok.
By the way does the new program version support the pioneer DDJ-400? I think I had the same problem when I tried to use it on a gig recently.
Jukka
Jukka
geposted Fri 22 Nov 19 @ 5:31 pm
ddj400 is supported.
geposted Fri 22 Nov 19 @ 6:28 pm
Hi. i am having the same problem too. When i load the song on one track the other track stops then continues. Im using Denon MC7000
geposted Fri 23 Oct 20 @ 12:28 am
geposted Fri 23 Oct 20 @ 12:31 am
Did you read the thread?
geposted Fri 23 Oct 20 @ 8:03 am
I just wanted to say Thank you DJdad , I had never experienced this but after reading your response, I checked and sure enough... Both my master and headphones were set to same channel 1&2. After changing headphones to 3&4 , seems to have fixed my situation. Many thanks ...this is the very reason I paid for the program, your support in times of need has been priceless. Michael aka DJ older than dirt haha.
geposted Fri 18 Dec 20 @ 7:34 pm
I have the same problem but i dint see your answers
geposted Mon 07 Feb 22 @ 6:02 pm
Most likely your master output and headphones output are switched in the audio config
geposted Mon 07 Feb 22 @ 8:05 pm
