Forum: VirtualDJ Plugins
Topic: VST or AU in VDJ?
PsYAuMHome userMember since 2019
is it possible to use third party plugins within VDJ?
geposted Mon 25 Nov 19 @ 5:51 pm
Yes, download the AU/VST and move the dll/[.bundle for macs...?] to .....\VirtualDJ\Plugins64\SoundEffect [this is for x64 vsts]
geposted Mon 25 Nov 19 @ 5:58 pm
IMO it's a pain in the a$$ that VDJ doesn't just use the default system VST directory, as the plugins do when installed, and as other software which uses VSTs does.
geposted Mon 25 Nov 19 @ 6:03 pm
Thanks for the reply.
It’s good to hear it’s possible but your instructions are not clear to me.
I am using mac if that helps.
Can you revise your instructions and make them a little bit easier to understand please.
Thank you
geposted Mon 25 Nov 19 @ 6:32 pm
geposted Mon 25 Nov 19 @ 7:13 pm
Thank you
geposted Tue 26 Nov 19 @ 2:52 am
