Topic: Suggested Feature
I would just like to suggest a feature which I don't think currently exists, called: TRACK LINK Which would allow 2 tracks to start at exactly the same time from any location or hot cue point with the push of a single button. This would be ideal if using an instrumental track and an Acapella track simultaneously or as a track comparison mode. Just a thought! I could use the feature as a producer as well. Also I miss the loopable Sample playback mode, which was ideal for drum loops to keep looping continuously, something which seems to be missing in 2020 version. Hope you can bring back the loop mode for samples.
geposted Fri 29 Nov 19 @ 10:14 pm
geposted Fri 29 Nov 19 @ 10:34 pm
