Topic: Name of "panelgroups"
Does anyone know the names of "panelgroups" related to the base skin?
I wanted to set up a script to change the panels with a click ...
Tnks
geposted Sat 30 Nov 19 @ 11:30 am
Show in a picture what you want to change
here's an example or 2
skin_panel '@pads16_deck1'
skin_panelgroup 'fx_deck1' +1
geposted Sun 01 Dec 19 @ 5:31 pm
Is there any particular reason why you can't just look through the XML yourself?
geposted Sun 01 Dec 19 @ 5:47 pm
Script learn in mappers would be easier, the placeholders in the xml don't make it obvious as to what the real name is.
geposted Sun 01 Dec 19 @ 6:02 pm
This is the panel
geposted Wed 04 Dec 19 @ 1:39 pm
If I knew which file to watch I had already done it.
Instead of being so strict, tell me which file to check. That would help you.
geposted Wed 04 Dec 19 @ 1:53 pm
skin_panelgroup 'loops_deck1' +1
skin_panel '@loopadjust_deck1'
skin_panel '@loopdefault_deck1'
skin_panel '@savedloops_deck1'
skin_panel '@looprec_deck1'
skin_panel '@loopbuttons_deck1'
geposted Wed 04 Dec 19 @ 2:39 pm
GOD BLESS YOU!
geposted Wed 04 Dec 19 @ 2:57 pm
No problem, Hail Satan.
geposted Wed 04 Dec 19 @ 4:41 pm
