Topic: Always updates 64-bit version
Hi. I'm having a problem. I work with Virtual DJ x86 because I use several plugins that are not compatible in the x64 version. Every time I update Virtual DJ it does it automatically in the x64 version and it stops working. I know that you can remove the automatic update, but it would be fine to detect which version you have. Thank you very much.
geposted Mon 02 Dec 19 @ 8:31 pm
Do you also have the 64 bit version installed or running?
Otherwise the update would not automatically change from 32 to 64
geposted Tue 03 Dec 19 @ 1:01 am
