Topic: Help with Debug
bpmPRO SubscriberMember since 2019
Hello,
Has anyone figured out how to make the debug statement work? I am running into the same issues as above. Getting some insight into the variables would be extremely helpful.
Additionally, the script only executes once and I need to restart the application. I am on version 8.4 b5402.
Here are some scripts I tried:
debug “deck 1 get_genre” = Text: deck 1 get_genre
debug `deck 1 get_genre` = no param
debug (deck 1 get_genre) = no param
deck 1 debug get_genre = Text: get_genre
deck 1 get_genre & debug = no param
deck 1 get_genre debug = nothing happened
deck 1 debug `get_genre`= `get_genre`
Thanks.
geposted Fri 06 Dec 19 @ 12:59 pm
I've never used it before but I've just tried this on a custom slider
effect_slider "shader" 2 & debug
geposted Fri 06 Dec 19 @ 1:32 pm
I'm not sure what you're wanting but perhaps var_list is what you want.
geposted Fri 06 Dec 19 @ 3:23 pm
Hi, Thanks for the tip. Unfortunately, I'm looking to see more of what the function is returning vs. what is inside the variable list.
For example, I'm trying to get the variables from get_beat_bar so I can process and use them later down the chain.
I try this:
get_beat_bar 16 & debug
And get "no param" for the debugging results.
Thanks.
geposted Sat 07 Dec 19 @ 12:03 am
NicotuxHome userMember since 2014
Maybe because debug do not handle return values...
In your example:
get_beat_bar 16 & param_cast float & debug
is working
get_var myvar & debug
is not
get_var myvar & param_cast & debug
is working
the bug with relative - mouse roll on slider :
set myvar & debug & get_var myvar & param_add 1 & param_cast & debug
Debug says :
1.03 (relative)
0.03 (relative)
and once debug window is closed it's forever, needs VDJ restart to open again
geposted Sat 07 Dec 19 @ 1:22 am
