hi everybody
weird issue..
i have milkdrop installed on my desktop :
hp desktop win10 64 bit & vdj 2020 (32 bit) (8.4 5454)
i5 3th gen
8 gb ram
intel hd graphics
dx12 installed
all windows drivers & updates are up-to-date
it works fine
when i try it on my other laptops :
hp laptop win10 64 bit & vdj 2020 (32 bit) (8.4 5402 stable version)
i5 3th gen
8 gb ram
intel hd 4000 graphics
dx12 installed
hp pavillion ,win10 64 bit & vdj 2020 (32 bit) (8.4 5402 stable version)
i7 8th gen
12 gb ram
4 gb nvidia graphics card & intel hd graphics
dx12 installed
dell laptop win10 64 bit & vdj 2020 (32 bit) (8.4 5402 stable version)
i3 3rd gen
6 gb ram
dx12 installed
it does not work..
i get a skin flickering & skin color change and the visualization stays black
is there something i am missing ?
any clues ?
i know about the shaders and i use some of them, but i am wondering as to why milkdrop works on the desktop and not the other laptops..
shaders are fine but milkdrop is also great (unless there would be a reason not to use them like maybe crashing the system or else)
thanks a lot for your time
weird issue..
i5 3th gen
8 gb ram
intel hd graphics
dx12 installed
it works fine
i5 3th gen
8 gb ram
dx12 installed
i7 8th gen
12 gb ram
dx12 installed
i3 3rd gen
6 gb ram
dx12 installed
it does not work..
any clues ?
geposted Sun 08 Dec 19 @ 12:19 am
Did you install via the installer? I ran in to this ages ago I didn't use the installer I copied the files from one rig to another and got flickering. Using the installer fixed it for me.
geposted Sun 08 Dec 19 @ 6:33 am
Yes, install was made through the installer within vdj-extensions
geposted Sun 08 Dec 19 @ 6:53 am
What I can see from your list is that it works with VDJ 5454 but not 5402.
I suggest you try updating one of the 5402 systems to 5454 and see what happens.
geposted Sun 08 Dec 19 @ 9:12 am
Actually it has been working that way since 8.3.
It just worked through all the versions (beta & public release)
geposted Sun 08 Dec 19 @ 9:36 am
I have the same issue. It doesn't seem to be related to the directx9 or 12 or whatever. It just doesn't work. I must say I have this problem on my desktop with AMD ryzen5 1400 Quad-Core 3.2 Ghz processor. 8.00 GB Ram memory and NVIDEA GeForce GTX950.
I hope to find an answer.
geposted Sat 21 Dec 19 @ 10:45 pm
YES!!! I love Milkdrop. So nice random fractals with awesome colors. Please bring it back.
geposted Sun 22 Dec 19 @ 8:57 am
Totally Agree.....Workout a way to bring it back.....Its an important part of my production..
geposted Wed 05 Aug 20 @ 7:27 pm
You can still use 32 bit VDJ if Milkdrop is that important to you.
geposted Wed 05 Aug 20 @ 8:29 pm
