Topic: Recent issues
I encountered 2 issues this past weekend, which is odd because I have been on my existing build for some time now:
1) VDJ is automatically syncing the BPM when hitting play. I have auto bpm set to no, and this only happens upon hitting play.
2) VDJ will randomly start a half beat prior to my hot cue point when selecting the hot cue. I say randomly because if I hit the same hot cue again, it could start at the hot cue point, as expected.
VDJ build 4291
geposted Mon 09 Dec 19 @ 4:26 pm
Check settings for smart cue or smart play
You are spot on...but very weird that this functionality was enabled (I didnt select it), and only on one deck...
Thanks for the quick reply!
