I have written a script for a custom button that when clicked reduces the master volume to 25% and starts automix. When clicked again, it waits until the current song is finished then stops automix and restores master_volume to its previous level. Works as intended and here it is:
automix ? repeat_start "stopLoop" 1000ms & songpos_remain 1000ms ? repeat_stop "stopLoop" & automix & get_var "mvol" & param_cast & master_volume : nothing : playlist_load_and_keep & automix & master_volume & param_cast & set "mvol" & master_volume 25%
The first time the button is pressed it doesn't light up but does when it's pressed for the second time and then goes out when the song finishes. I thought it would be nice if the button lit up on the first press, started flashing on the second press then went out when the song finished and auto mix turned off. All attempts to get this behaviour putting in blink and off and on verbs in what I thought were the appropriate places have failed! I think I'm missing some fundamental rules about how button illumination is decided because in my experiments I discovered that a custom button with this action:
var_equal "blink" 0 ? set "blink" 1 & off : blink & set "blink" 0
starts blinking on the first click but never stops how ever many times it's clicked whereas just adding & nothing on the end like this:
var_equal "blink" 0 ? set "blink" 1 & off : blink & set "blink" 0 & nothing
works as I expected ie on first click it starts blinking and on the second click it stops.
Can someone explain what's going on and help to get my button blinking as I would like please? I'm using VDJ 8.4 b5403 on an iMac running MacOS 10.15.1
geposted Wed 11 Dec 19 @ 4:44 pm
var_equal "blink" 0 ? off & set "blink" 1 : blink & set "blink" 0
try that instead, lights evaluate constantly, so the way you had it before it got to "set "blink" 1" and the script read it and decided "well that isn't true, so go no further"
This isn't something I've read or been told just my best guess interpenetrating what I've tried.
geposted Wed 11 Dec 19 @ 5:04 pm
Thank you for your suggestion but that doesn't make any difference.
geposted Thu 12 Dec 19 @ 3:55 am
Can any VDJ script experts point me in the right direction please?
geposted Sat 14 Dec 19 @ 5:46 pm
I (finally) found a solution to this. The <button> element has a "query" attribute which can be used to return "on", "off" or "blink" to control the button illumination. For example:
query="play ? on : blink"
You can do similar with pads.
geposted Wed 20 May 20 @ 10:16 am
