Hi. I need your help
all this fles are locate on they are in different folders. and in connection with this and their number, it is not possible to prescribe the Relocate function separately in the same way and it is not possible to search for and replace records in the Database file by one line.
I have Mac Os High Sierra. I have already found some of them and am ready to put them in a separate folder, but, these records do not change the path (using the "MoveTo" function because they are not in their places. Creating paths again and sorting 6000 files is a very long time.
Waiting for your suggestions
geposted Thu 12 Dec 19 @ 12:41 am
