Topic: Independent pad page setting
Dear all,
Is it possible to save the parameter "independent pad page" for the main controller?
I explain: I would like to have an independent pad page on the main controller ( Pioneer DDJ 800), and on the auxiliary controller (Kontrol F1) the same pad page as on the skin. I can select it under the controller/ DDJ 800 setting / independent pad page , it works fine, but every time I close Virtual DJ this setting is lost and I have to come back to select in the settings.... Any ideas? Thank you very much.
geposted Thu 12 Dec 19 @ 6:41 pm
As far as I know there's no script [as of now] that can set "independence" you could however hardcode the pads of your controller.
A script would be good, but hardcoding is a way to do it now.
geposted Thu 12 Dec 19 @ 7:15 pm
Yes good tip, I will hardwrite on the main controller mapping . I just use savedloops and hotcue on the DDJ, while on the F1 I use several different functions (sampler, videoFX, sound2light,...). I had already done in this way on my old controller.
Best.
geposted Sat 14 Dec 19 @ 9:22 am
