Hi all, I have problems playing some videos that I use to play before, they seems to be playing however there is no sound at all, also on the Rhythm windows I only see dots, instead the graph that usually appear when the sound load up. I did some updates on the klite codec and update my Windows 10 however nothing has resolve this issue.
Thanks!
Thanks!
geposted Fri 13 Dec 19 @ 4:06 pm
VDJ is using its own codecs, updating klite does not help
You may try to verify your tracks are already playing in mediaplayer classic or vlc
and try to downgrade/upgrade to previous/early VDJ version http://www.virtualdj.com/download/build.html
geposted Fri 13 Dec 19 @ 4:55 pm
