Topic: Video plays but not sound Ver 8.4
lapenaPRO InfinityMember since 2007
Hi all, I have problems playing some videos that I use to play before, they seems to be playing however there is no sound at all, also on the Rhythm windows I only see dots, instead the graph that usually appear when the sound load up. I did some updates on the klite codec and update my Windows 10 however nothing has resolve this issue.
Thanks!
geposted Fri 13 Dec 19 @ 4:06 pm
NicotuxHome userMember since 2014
VDJ is using its own codecs, updating klite does not help
You may try to verify your tracks are already playing in mediaplayer classic or vlc
and try to downgrade/upgrade to previous/early VDJ version http://www.virtualdj.com/download/build.html
geposted Fri 13 Dec 19 @ 4:55 pm
