Topic: Key suggestions in VDJ extended(?)
Hi!
I see a bunch of suggestions key compatible(?) harmonic(?) wise in VDJ, which I haven't seen anywhere else.
Can you break them down for me?
In this example Key 4A is playing:
https://gyazo.com/ad9f6a6a597be9addb2c29f7d9f3ad38
Where I can see:
4A = harmonic compatible
3A = -1 semitone down = harmonic compatible
5A = +1 semitone up = harmonic compatible
But....
09A = ?
11A = ?
and some others...?
I'm aware of the White (Exact: A bright check mark indicates the song key in the active deck is compatible with the file in the browser)
+ Gray (Close: A darkened check mark indicates the song key in the active deck is off by 1 semitone with the file in the browser)
geposted Mon 16 Dec 19 @ 6:08 pm
Plus 1 on the Camelot wheel, [A.K.A. a Major 5th]
Minus 1 on the Camelot wheel, [A.K.A. a Minor 4th]
Plus 2 on the Camelot wheel, [A.K.A. Energy Boost]
Plus 7 on the Camelot wheel, [A.K.A. Mild Boost]
Plus 4 on the Camelot wheel, [A.K.A. Major 3rd]
Minus 3 on the Camelot wheel, [A.K.A. Minor 3rd]
Thanks!
09A = E minor
04A = F minor
By shifting 09A one semitone up, it becomes 04A, thus being harmonically matched.
11A = F# minor
By shifting 11A one semitone down, it also becomes 04A, thus being harmonically matched
