Hello, I have a couple of VST I'd like to use with Virtual DJ, I followed the manual instructions and copied the 32 bit dll in the C.\Users\Alessandro\Documents\VirtualDJ\Plugins\SoundEffect folder, but when I try to select an effect on Decks or Master the VSTs does not appear at all in the list of available effects. If I install audio fx effects from Extensions in Virtual DJ setup they work fine.
geposted Wed 18 Dec 19 @ 10:42 am
Are you using the 64 bit version of virtualdj perhaps?
geposted Wed 18 Dec 19 @ 12:00 pm
Yes, I understood now, I have to copy 64 bit dll files in Plugins64, I'm using Virtual DJ 2020.
Thank you for putting me in the right direction :)
geposted Wed 18 Dec 19 @ 5:47 pm
