Topic: Early Access b5474
I updated to EA b5474 yesterday or Tuesday. Today it is not there, the latest EA build is b5466.
I used b5474 at last night's Christmas Party gig with no problems.
Is there a problem with b5474 and should I return to b5466?
System Specs;
MacBook Pro 15” 2017, 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Mojave 10.14.6, 500gb SSD, external WD Passport Ultra 2Tb HD containing Music, Video & Karaoke databases and is formatted NTFS, I use the Paragon plugin with NTFS for Mac.
VirtualDJ 2020 b5474 and Controllers - Denon MC6000 MkII, Denon MC7000.
geposted Thu 19 Dec 19 @ 10:10 am
If you are using video there might be an issue moving the preview window around. We are currently investigating the possible issue
geposted Thu 19 Dec 19 @ 10:52 am
No, not using video.
geposted Thu 19 Dec 19 @ 3:20 pm
Oops! Don't have any video output, but, occasionally I switch on video in the preview window then double click to make it full screen on the laptop.
I did that tonight with a busy dancefloor and got the spinning pinwheel. I then realised that I should not have done that, so, I clicked a couple of times again to reduce the window and then VDJ crashed suddenly. It returned within a few seconds and continued playing the song.
I was on the internet, so, you should have the crash log and hopefully help you find a solution
Just tried it at home VDJ crashed immediately. I then ran b5466 and tried the same videos and that version works fine.
I will return to build b5466 for the time being.
Cheers
Les
geposted Fri 20 Dec 19 @ 2:35 am
