Hello, so I have started working with VDJ just a few weeks ago and I need to put the songs by order into the automix. I made and folder on my computer that has all the songs renamed so that every song has an number in front of it. (So it looks like: 01. Beyonce... you get the point). When I try to load that playlist by order into VDJ, it just loads itself randomly and I dont know how to fix that. If someone knows the solution I would be verry happy. Thank you.
geposted Wed 25 Dec 19 @ 9:44 pm
search for "Reset sort order " on this page of the manual
https://www.virtualdj.com/manuals/virtualdj/interface/database/playlists/index.html
geposted Wed 25 Dec 19 @ 11:15 pm
Cant find any help on there
geposted Thu 26 Dec 19 @ 1:04 pm
I just clicked on the link and searched for "reset" and found exactly what WickedMix suggested.
geposted Thu 26 Dec 19 @ 4:01 pm
yes reset is there
but not relevant : this will only sort in unsorted order -- the order the tracks were added to folder or to playlist -- may be really random
just add "filename" column to automix display and sort by filename
geposted Thu 26 Dec 19 @ 4:35 pm
You say you made a folder with all the songs numbered. You need to load each song manually into Automix in the numerical order that you want them in. Then save the Automix as a playlist. You can then load that playlist into the browser or Automix and they will be in the order that you created the list.
geposted Thu 26 Dec 19 @ 4:42 pm
if you saved it in order to begin with my post above has your answer. if you did not drag and drop in order and save it again.
geposted Thu 26 Dec 19 @ 8:07 pm
