Sometimes I have to click the "MT" button to make songs play at their original pitch. Sometimes it needs to be on, sometimes it needs to be off. Is there a way to simply have the songs to always play at their original pitch?
Thanks,
--Kizz
Thanks,
--Kizz
geposted Fri 27 Dec 19 @ 5:20 am
Nothing to do with the Blocks skin. More likely that you need to check the deck options button (to the right of the PLAY button) and make sure everything is unchecked.
geposted Fri 27 Dec 19 @ 6:40 am
Everything was already unchecked. The problem went away when I deleted the Blocks skin and reverted back to "Old 2 decks".
geposted Fri 27 Dec 19 @ 7:00 am
Well, I installed the Block skin again and now it's not doing it. Must have been a glitch.
geposted Fri 27 Dec 19 @ 7:26 am
