Hi,
I have a Pioneer DDJ-SX3 and in VDJ2020 I cannot get any audio from the sampler sidelist.
Everything plays ok but I have no audio, maybe its a routing issue?
In audio setting the sampler is set to channels 12 & 13, How do I change this to Channel 4?
Thanks in advance
Wayne
Thanks in advance
Wayne
geposted Sat 28 Dec 19 @ 1:43 pm
The small button in the sampler and choose master or channel output.
geposted Sun 29 Dec 19 @ 6:13 am
Hi,
Thanks for your reply, but this option isn't on vdj2020?
W
W
geposted Sun 29 Dec 19 @ 12:47 pm
Yes it is. What's your audio config? Please post a screen grab.
It should be as shown in the SX3 Setup Guide...
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsx3/setup.html
geposted Sun 29 Dec 19 @ 1:47 pm
Hi,
Here it is.
W
Here it is.
W
geposted Sun 29 Dec 19 @ 2:06 pm
If you have a sampler output in your audio config, vdj will use that output for the sampler instead.
If you want the sampler on the deck output, you should remove the sampler output from the audio config.
But since it looks like the SX3 has a dedicated sampler output, it is probably better to check the SX3 manual on how to activate the sampler/change the volume.
geposted Sun 29 Dec 19 @ 2:44 pm
Hi,
I have contacted Pioneer Pro Dj support.
Surely someone here also has an SX3, I cant be the only one with this issue?
W
W
geposted Tue 31 Dec 19 @ 2:16 pm
Which issue do you have exactly?
geposted Tue 31 Dec 19 @ 6:45 pm
