Topic: File browser opens Loading Tracks
Hi
While loading some tracks into each deck in VDJ2020 by drag & dropping as the track is loaded onto each deck VDJ opens a folder browser to search for tracks?
Why is it doing this, how can I stop it?
Thanks
Wayne
geposted Sat 28 Dec 19 @ 5:10 pm
Nope. Not to search for tracks. Read what it says - "select folder for slideshow".
You have enabled the option to run pictures when you're playing audio-only files.
Hi
Thanks for reply.
Vdj is the default version I haven't changed any settings, yet.
This is only happening with some files not all.
I've never seen this before in previous versions.
W
