Every time that I close the program the cue's that I have marked disappear, and the BPM's for most of the songs are no longer there. Has there been an update that has caused this? It just started this weekend. I have a MacBook Pro, and I updated the software on it on Friday (Dec 27th). I look forward to your response.
geposted Mon 30 Dec 19 @ 7:13 pm
This is happening to me now. Did you find a way to fix it ?
geposted Wed 30 Sep 20 @ 11:18 pm
ive noticed this about a week ago, i just started resetting my cue points, hopefully there's a fix
geposted Thu 01 Oct 20 @ 12:07 am
Is your music on an external drive (that you created on other computer)
Or copied the database over from other computer?
If so, you might have a write permission issue, that you need to resolve.
OR, if on macOS, try give VirtualDJ full disc access
https://www.virtualdj.com/wiki/Settings-not-saving.html
geposted Thu 01 Oct 20 @ 8:23 am
This sounds a lot like the issue that just showed up for me: https://www.virtualdj.com/forums/237621/VirtualDJ_Technical_Support/REALLY_weird_issue_after_updating.html
geposted Thu 01 Oct 20 @ 11:56 am
