Topic: DDJ SZ Sound Quality
Dj HmiLE userMember since 2011
Hello Guys. I use the VDJ 2020 with DDJ SZ (Windovs 8.1). I have a sound problem. The sound is distorted and there are loud noises in the speakers. With Serato, Rekordbox, Traktor the sound is Ok.
geposted Thu 02 Jan 20 @ 1:29 pm
Sounds odd.. if it works with other software. Its likely the driver audio buffer size though.
Try set to 256 or 512 samples... in the Pioneer Settings Utility.
geposted Thu 02 Jan 20 @ 1:58 pm
Thanks!
geposted Thu 02 Jan 20 @ 2:24 pm
