Topic: Script for "Relocate Missing File"
Can this be scripted? Can't find it under the current list.
As always, TIA!
geposted Sat 04 Jan 20 @ 7:27 am
nope it can't.
geposted Sat 04 Jan 20 @ 7:29 am
Limitation based on the fact that it brings up an OS window?
I've also noticed that some songs disappear again when "relocated." For example, when I complete the command, then navigate away from the playlist holding the offending files, as soon as I go back to that playlist, they are marked as missing again.
Any insight?
geposted Sat 04 Jan 20 @ 7:43 am
If you know a bit of JavaScript you could always check out the package I just released which would allow you to script things like this:
https://github.com/silverspex/vdj-data
If I get the time I might write a demo script that will scan drives to update path or move them to a default one. But no promises - I'm drowning in work these days.. see first if it's something you can use.
geposted Sat 04 Jan 20 @ 10:22 am
DMayock13 wrote :
Any insight?
Probably related to when VDJ writes to the DB. As far as I'm aware, VDJ saves things when it closes.
geposted Sat 04 Jan 20 @ 11:07 am
groovindj wrote :
DMayock13 wrote :
Any insight?
The database is saved almost instantly after changes are made, as are playlists.
Using the relocate function should also immediately update the playlists.
The only things stored on exit are the settings and the automix/sidelist/karaoke lists.
geposted Sat 04 Jan 20 @ 3:47 pm
