Topic: Crossfader move start
Hi
Please help me this action;
If I move the crossfader from 0 or 100, it hot_cue the incoming deck.
Not fader start and fader stop.
Like fader start only but this time if you move and it start play and you come back and move again it start again.
Thanks
geposted Mon 13 Jan 20 @ 8:34 pm
Are you using any specific hardware/controller/mixer ? If yes, which one ?
Or is this happening by just moving the crossfader on the screen/computer ?
geposted Mon 13 Jan 20 @ 10:46 pm
I use Numark Mixtrack Platinum and also on screen too Boss
geposted Mon 13 Jan 20 @ 11:11 pm
So FaderStart and FaderStartStop settings are set to No ?
Mixtrack Platinum has some internal Fader Start/Stop functionality, as described here.. http://www.virtualdj.com/manuals/hardware/numark/platinum/layout/mixer.html but for that, SHIFT needs to be pressed while moving the faders. Is this the case ? Or maybe SHIFT is "stuck"/pressed ?
but again, that wouldnt explain the same behavior when moved from the skin, so most likely its the settings above.
geposted Tue 14 Jan 20 @ 12:13 am
I can't get it clear Boss, can't you give the action Boss
geposted Tue 14 Jan 20 @ 12:30 am
Boss is like for keyboard so that I can use without controller.
Help me please.
Thanks
geposted Wed 15 Jan 20 @ 3:03 pm
Please Bosses am still waiting
geposted Sat 18 Jan 20 @ 1:31 am
Please nothing like that, if not tell me.
Thanks
geposted Wed 05 Feb 20 @ 6:39 pm
lincol2PRO InfinityMember since 2011
geposted Wed 05 Feb 20 @ 7:21 pm
And God bless.
geposted Wed 05 Feb 20 @ 8:18 pm
